1989 Acura Legend fluctuating Idle when braking and idle
1989 ACURA LEGEND
150,000 MILES • 6 CYL • FWD • MANUAL
NEENJAKEELUR
I just bought my car a week or so ago...and I test drove it and it worked fine..but a copule days ago it started to die when I would brake with the clutch in. It will start back up just fine, no power loss or slippage just really erattic idle..(200-1500rpm and idle) The car has new plugs, cap and and wires...is there anything that could be causing this? Also under acceleration the idle is fine no problem. I think possibly clogged injectors or fuel filter...again the erattic rpms only happen when it warms up a bit and under braking conditions..any help?
Nov 22, 2008 at 8:01 PM
DAVE H
  • 13,384 POSTS
try replacing fuel filter and adding a fuel injector cleaner first .. see if the helps .. if not repost for further help ?
Nov 22, 2008 at 10:33 PM
NEENJAKEELUR
thanks for the tips i will definitly try that, Im used to older muscle cars and stuff so this crap throws me for a looopty loop haha
Nov 22, 2008 at 11:30 PM
