Hi MAMBO1234,
The oil leaking should be due to a bad valve cover gasket and replaceing it should solve the problem.
The loss of coolant should be checked as some hoses or connections of the cooling system might be leaking. You should top up the coolant, bleed the system and then test drive the vehicle. If you wish to have a fast answer, a pressure test of the cooling system would be recommended.
SPONSORED LINKS
Friday, January 30th, 2009 AT 8:20 AM
