What would cause a steady drip of oil only when started?Not the oil filter, oil pan gasket, or no valve or cam covers leaking.
Mar 20, 2008 at 10:19 PM
SERVICE WRITER
✓Experienced Mechanic
Anywhere there is oil pressure. Not sure if this has oil cooler lines, but that would be a common point on many. Oil pressure sending unit maybe. Main seal.
You need to get good lighting use mirrors if needed and start looking.
