1988 Acura Legend Cooling Fan Motor
SCTTCUTLER
Engine Cooling problem
1988 Acura Legend 6 cyl Front Wheel Drive Automatic
I have an Acura Legend 1988 LS. I was unable to pass smog because my cooling fan would not come on when the car idles and starts to over heat. i have taken the fan motor out and hooked it up to the battery and it works. i have checked the fuses and they are all good. I am wonderring if it could be the fan control swotch aor the relay. I am trynig to get the fan to work.
Jun 10, 2010 at 6:27 AM
BLUELIGHTNIN6
  • 16,542 POSTS
yes check for faulty cooling fan relay(s). if OK check engine coolant temp. sensor
Jun 10, 2010 at 4:01 PM
