I have a 1996 Acura Integra Ls with 122,000 miles automatic. The timing belt snapped off on me so i changed the timing belt and the water bump. Also i changed the crank shaft sensor cause the wires were ripped, and changed the crank sprocket at the very bottom. I aligned the cam gears and tried to start the car and it wont start so i took the spark plugs out to see if it was the spark plugs and it checked to see if the spark plugs were giving out any spark and noticed that they don't give out any sparks. What can be the problem.
Nov 27, 2007 at 6:14 PM
