Acura Integra Flooded No Start
DBOZ
ok i have a 96-99 gsr engine running a p28 ecu in it . I bought the car from a friend last night and drove it home car ran great when i got to his hous the car started right up . he said first thing in the morning whe its cold the car has a hard time staying started. if you hold the gas pedal down a bit to keep the rpm's up the car is fine for the rest of the day after that . The car does have a fuel cut off switch which i turned off due to the fact i live in a high crime area. This morning i go out to get in it and start it up and it starts and then dies about 2-3 times i got it briefley started and then it died again . I tried cranking it and cranking it but no dice it wont start so i pulled the plugs out and disconected the injectors and tried to see if the car was flooded ( i could smell gas) I looked into the compustion chamber and the tops of the pistons looked damp . i put everything back together and left it and went to work . is letting the car sit going to help it ? keep in mind when i get home from work it would have sat for 9-10 hours will the gas evaporate or do i have to do something ??????? .Thank you
Sep 20, 2007 at 7:50 AM
BRUCE HUNT
  • 3,754 POSTS
The gas will evap that you can count on. Sounds like I would be looking at the fuel pressure regulator or the injectors as the problem cause. BUT I would suggest that you not rule out poor delivery of the spark to the plugs.
Sep 20, 2007 at 11:09 AM
Suggested Repair
Let the car sit so the excess fuel evaporates. Then check the fuel pressure regulator and injectors for leaking fuel, and also verify spark delivery to the plugs.
Conversation Summary
The owner of an Acura Integra with a 1996-1999 GSR engine and P28 ECU says it is hard to keep running when cold unless the throttle is held, then later flooded and would not restart. The plugs and piston tops looked damp and smelled of fuel. The expert says the fuel will evaporate and recommends checking the fuel pressure regulator or injectors, while not ruling out poor spark delivery.
