1991 Acura Integra flood damage
1991 ACURA INTEGRA
170,000 MILES • 4 CYL • 2WD • AUTOMATIC
GOATIS00
My '91 Integra was recently damaged by flood water. I was driving through a deep puddle when she stalled out and died. I changed the spark plugs and changed the oil, and the car was able to start. The problem is, it runs a little shakey, and only for a short while. I know there are more than a few problems that may be causing this, but any help is apperciated
Jun 16, 2008 at 2:28 PM
  • 31,937 POSTS
Hi there,
you should have a scan done and check for any fault codes, this will give you an indication as to where any problems may lie. start here.
mark (mhpautos)
Jun 17, 2008 at 12:09 AM
KHLOW2008
  • 41,814 POSTS
Hi goatis00,
Check for water in distributor cap.
If idliing is poor, do a compression test, you might have bent con rod if too much water had been sucked into the cylinders.
Jun 20, 2008 at 12:35 AM
