acura abs leak
CHARLES1003
i have a 1995 acura integra LS, 110K with a leak in the ABS that i can not find. any idea where to start?
Jul 28, 2007 at 1:54 AM
BRUCE HUNT
  • 3,754 POSTS
Start with the master cylinder. If the foot pedal gets weak or heads for the floor, check the master. Don't forget to look inside the vehicle as the leak can be the seals where the pedal rod connects to the master. After that I would check each wheel and the hoses.
Jul 31, 2007 at 12:51 AM
