2004 Acura Integra SRS Light Illuminated on Instrument Clus
2004 ACURA INTEGRA
100,400 MILES • 4 CYL • 2WD • AUTOMATIC
RICK 1028
How can I reset the SRS light or what are the options in having the problem diagnosed? Is this a dealer only fix?
Jan 31, 2008 at 1:35 AM
JEREMIAH
  • 217 POSTS
first of all,acura stopped production of integras in 2001.
i will give you instructions for 2001.
look for the under dash fuse/relay box.
you should see a 2 wire connector with nothing connected to it.you need to jump the two pins in the connector in exact order;
Make sure the ignition switch is OFF
jump the connector
Turn the ignition switch ON
The SRS indicator light comes on for six seconds and goes off
Remove the jumper from the connector within four seconds after the SRS indicator light went off.
The SRS indicator light comes on again. Reconnect
the jumper to the connector within the four seconds after the SRS indicator light goes on.
remove the jumper when the srs light goes off.
srs light will blink twice to let u know that it is clear.
YOU WILL ATTEMPT THIS SEVERAL TIMES BEFORE YOU GET IT RIGHT OR GIVE UP.GOOD LUCK!
Feb 15, 2008 at 2:20 PM
