Engine has a rough Idle?
120,000 MILES • 4 CYL • FWD • MANUAL
LARRYM1845
Sometimes it will start a rough idle.Up and down to where it almost dies.Then it clears itself up and is fine.A/c is not on at the time.New wires,plugs filters.We checked for vacuum leaks and cleaned the aic valve.
Only does this once in awhile.But it stops just as soon as it starts.Im thinking a sensor or elctrical part.
May 10, 2009 at 9:25 PM
KHLOW2008
  • 41,812 POSTS
Hi larrym1845,
This could be caused by uneven compression due to minor leaks caused by valves. THis guide can help us fix it
May 12, 2009 at 7:36 AM
LARRY1845
I noticed the pcv valve was in two different parts.I replaced it and everything is fine now.Thanks.
May 14, 2009 at 9:15 PM
