2000 Acura Integra No Cold Air
GBADOO
Car: Acura Integra 2000 GS 1.8 auto, 87,300 miles
On 7/20/07. I used my air conditioning. It was working OK but not strong. It has not been all that strong on very hot days since I bought the car at 75,000 mi in March '06, but worked OK with recirculated air.
I next tried to use it on 7/27/07. No cold air, not even cool. I had a mechanic look at it: clutch engaging, hi-low pressure test numbers OK (but mechanic suggests this does not say anything about HOW MUCH refrigerant is in system).
When I turn on AC, the box on lower right makes a hissing noise, a cross between "SSSSHHHH" and "SSSSSSS". When I turn it off, it briefly gets louder, then ceases, although you can still hear fan. This noise may have always been associated with AC, but since there was nothing wrong, I never noticed it.
I looked at linkage from manual slider to box at lower right (is this the blend door?). All linkage seems to be OK.
Mechanic (not dealer, but experienced factory-trained Honda mechanic) suggested trying a purge and recharge as first step - cost about $140.00.
Before I spend the money - is there anything else this could be? Is it not kind of sudden to go in 1 week from reasonably effective cooling to none at all? When there is still 80# pressure on the high side?
Could there be a sudden leak? How would you find it?
Aug 2, 2007 at 10:26 AM
GREASE MONKEY
  • 23 POSTS
I do not understand when the guy said " hi-low pressure test numbers OK (but mechanic suggests this does not say anything about HOW MUCH refrigerant is in system"
The gauge pressure readings are about the only way to tell about the system. Ask friends ,co-workers. ect if they know of any good A/C shops around and take it to them.
It sounds like it is low on 134a to me but I can not be sure with out knowing the Hi and Lo gauge pressure readings.
Let me know how it turns out. I hope I helped you.
Aug 11, 2007 at 4:32 PM
Suggested Repair
Have a reputable A/C shop read the high- and low-side pressures before a purge and recharge. Low R-134a is possible, but the charge cannot be judged without those readings; check for a leak if the system is low.
Conversation Summary
A 2000 Acura Integra GS lost all A/C cooling within a week after previously cooling weakly. The compressor clutch engaged, a mechanic reported acceptable high and low pressures but said that did not show refrigerant quantity, and a hiss came from the lower-right box when the A/C was on. Linkage to the blend door appeared intact, and a purge and recharge was suggested. The expert said gauge readings are the proper way to assess the system, suspected low R-134a without exact pressures, and recommended a good A/C shop.
