2000 Acura Integra oil leak in distributor
2000 ACURA INTEGRA
JAVIERGARCIA426
Engine Mechanical problem
2000 Acura Integra 4 cyl Two Wheel Drive Automatic
do i have to dissasemble the distributor to replace the o ring or just remove the distributor and change the o ring, thank you.
Sep 9, 2010 at 2:04 PM
KHLOW2008
  • 41,814 POSTS
Hi javiergarcia426,
If it is just the O-ring, it not be disassembled, removing the distributor would enable you to replace it. If it is from within the distributor, then it has to be disassembled.
Remove the distributor cap and note the rotor position before removal. During installation, turn rotor to same position to enable easier plugging in of the distributor.
Sep 9, 2010 at 6:56 PM
