2000 Acura Integra fuel warning light
2000 ACURA INTEGRA
125,000 MILES • 4 CYL • FWD • MANUAL
PENG00GSR
hey i got a 00 acura integra gsr my fuel warning light never come on when fuel gets low wondering if you'll can help i usually run the fuel gauge close to the red line before refueling it.
Apr 28, 2010 at 7:45 AM
BLUELIGHTNIN6
  • 16,542 POSTS
well the easiest and best fix would be to not let it run that low, because that is very hard on the fuel pump...but most likely the cause of the low fuel light not coming on is a faulty fuel sending unit, the low fuel level sender is part of the entire fuel level sending unit.
Apr 28, 2010 at 10:22 AM
