2000 Acura Integra Coolant temperature goes up.
124,500 MILES • 4 CYL • FWD • AUTOMATIC
YAMAHUES1
  • 6 POSTS
I have a 2000 Acura Integra LS. I noticed when driving the car and then come to a full stop, the temperature goes up nearly close to 'H'. But as soon I gas it, temperature goes back to normal. Happens intermittently. Check the coolant level, okay. Check for leaks, none. Could it be my thermostat going bad? Any feedback is greatly appreciated. Thanks.
Mar 11, 2008 at 7:12 PM
SERVICE WRITER
  • 9,123 POSTS
Might be a t-stat sticking or other restriction. Is the radiator cold?
I have seen waterpump on there way out do similiar as well but fairly rare.
Has there ever been stop leak added?
What is the record on coolant flushes?
Mar 12, 2008 at 7:34 AM
YAMAHUES1
  • 6 POSTS
- Radiator temp is at normal.
- Changed the timing belt and waterpump at 95k.
- Never.
- I'm the second owner, bought the car when it had 65K. Changed coolant and thermostat at 78K. Then changed coolant again at 109K, but not thermostat.
Mar 12, 2008 at 8:00 AM
SERVICE WRITER
  • 9,123 POSTS
Thanks for that info. Thats tales a little cloudyness out. I would try a thermostat if it was mine. The trouble to take it out to test it...(especially being intermittant) I would just put in a new one. The intermittantcy and the restricted flow thoughts help support this. It's possible of other circulation restrictions, but the t-stat is more common. Or don't do anything and monitor the situation until it is more consistent or does peak into the red on the gauge. Which you don't wnat.
Mar 12, 2008 at 8:37 AM
YAMAHUES1
  • 6 POSTS
Will do just that. Thanks for your help and advice. Now I feel more confident.
Mar 12, 2008 at 9:50 AM
