2000 Acura Integra Check engine light
2000 ACURA INTEGRA
ANNESIROISA
Engine problem
2000 Acura Integra Two Wheel Drive Automatic 111000 miles
After having my car serviced 3 months ago, the ABS light kept lighting up and then 1 month ago the check engline light. I took my car to the dealership last week and they did a scan which resulted in Code P1362 TDC no signal. They reset the system but the check engine light still lights up. I called the dealership and they told me that if it stayed lit, I would probably have to change the distributor. Does that make sense to you?
Feb 19, 2008 at 9:20 AM
2CARPRO JACK
  • 11,533 POSTS
Yes it does, the TDC sensor is in the distributor and they had problems with them. not an unheard of repair for those cars
Feb 19, 2008 at 9:26 AM
