2000 Acura Integra Can't advance timing enough after changi
2000 ACURA INTEGRA
95,000 MILES • 4 CYL • FWD • AUTOMATIC
WEATOE
After changing my timing belt, I can't turn the distributor enough(counterclockwise) to advance the timing up to 14 degrees. The farthest it will go before the base bottoms out is about halfway between the white TDC mark and the three red marks where I need to be(roughly 9 degrees). I'm timing it right, jumping the service connector etc., although jumping the service connector doesn't seem to change the marks when using the timing light. I know its jumped though by looking at the engine light come on on the dashboard. I double checked that the camshafts are aligned and they are. My intution tells me that the crankshaft pulley must be retarded one tooth. Is this a reasonable assumption? I just bought the car so I dont know what it ran like before, but it still gets 25 mpg with this issue. It seems to run fine, but seems like it could have a little more punch. Thanks for the help guys!!!
Mar 13, 2010 at 12:13 PM
KHLOW2008
  • 41,814 POSTS
Hi weatoe,
The timing belt has been installed off 1 tooth.
Mar 13, 2010 at 9:02 PM
