1999 Acura Integra water pump
160,000 MILES • 4 CYL • FWD • AUTOMATIC
XXTERRYXX
is it possable to use bars leak for a leaky water pump?
Dec 23, 2008 at 12:52 PM
F4I_GUY
  • 3,302 POSTS
I am not a fan of using any stop leak addictive. The problem with these products are that they are designed in such a way that they can end up clogging your heater core and radiator which use very thin fins/ galleries to transfer coolant. I would recommend you replace that water pump and possibily the timing belt if its contaminated with coolant.
The stop-leak will not work.
Dec 25, 2008 at 3:46 AM
