your rough idle, is a bad egr valve. and shakes and vibrates, you need to have inspact on -front brake rotor, ball joint upper, wheel bearing front and tie rod end, these will make you car shakes and vibrates if they are going bad.
Oct 22, 2009 at 6:19 PM
