1999 Acura Integra Pressure
CHULA0206
Engine Performance problem
1999 Acura Integra 4 cyl Front Wheel Drive Manual 134k miles
I can't figure out why my 99 Acura Integra GS-R doesn't have any oil pressure. I have replaced the oil pump with a brand new one and I have had the block rebuilt. Any suggestions?
Nov 13, 2009 at 2:20 PM
  • 31,937 POSTS
Hi there, what is the cold idle and hot idle oil pressure, what is the pressure at 2,500 RPM's are you using a mechanical gauge to check the pressure, is the oil pick up ok, a cracked pick will cause low pressure.
Mark (mhpautos)
Nov 13, 2009 at 3:11 PM
