1999 Acura Integra Is There 2 Fuel Filters On A 94-01 Integ
68,000 MILES • 4 CYL • FWD • MANUAL
JIMMYL645I
  • 39 POSTS
i notice theres 2 Fuel Filters 1 in the engine bay and 1 under the car..
iam trying to replace them myself and it seems like i only have to replace the 2''+ fuel filter located in the engine bay correct?
or would the one located under the car would need to be replaced also.
Thanks, Will Definately Leave Feedbacks
JL
Jan 12, 2009 at 1:06 PM
DAVE H
  • 13,383 POSTS
my manual is only showing one filter fitted to the acura ..?
FUEL FILTER
Removal & Installation (Integra)
Release fuel system pressure. See FUEL SYSTEM PRESSURE RELEASE . Support fuel filter with wrench, and remove 12-mm banjo bolt. Remove fuel feed pipe from fuel filter. Remove fuel filter clamp and fuel filter. To install, reverse removal procedure. Install NEW banjo bolt and fuel feed pipe washers. Clean flared joint of high pressure hoses thoroughly before reconnecting.
Jan 12, 2009 at 2:36 PM
