1999 Acura Integra Gas Leak
1999 ACURA INTEGRA
75,000 MILES • 4 CYL • FWD • MANUAL
JER_ERD
Helllo,
I just put on a new intake manifold,throttle body and fuel rail. When I started the car gas was dripping, pretty heavily, from somewhere around the middle of the intake manifold. I can't tell if it was coming from underneath the manifold or not. What could be the problem here? The fuel injectors are original but have new rings.
Thanks for your help.
Jeff
Jun 21, 2009 at 12:51 PM
F4I_GUY
  • 3,302 POSTS
It is either coming from
a) the injector seals
b) fuel pressure regulator seal
c) fuel filter to fuel rail line and/or the washers.
Those are the only three possibilities. Make sure the injector seals are fully seated.
Jun 23, 2009 at 10:07 AM
