1998 Acura Integra wrired brake lights
1998 ACURA INTEGRA
130,000 MILES • 4 CYL • FWD • MANUAL
EDOUBLEG
i have a crazy problem going on with my car. the brake lights work fine when i' m driving it. BUT the right side won't come on when i brake.. when my running lights are on. if the running lights are off it works. help.
Nov 15, 2009 at 2:37 AM
KHLOW2008
  • 41,814 POSTS
Hi EdoubleG,
The lighting circuit has a bad ground causing the symptoms desctibed.
Check the right taillight bulb sockets and wire harness grounding connections.
Nov 19, 2009 at 3:01 AM
