1998 Acura Integra Ticking noise while braking under soft p
143,000 MILES • 4 CYL • FWD • AUTOMATIC
BORNFLIRT
I am hearing this ticking noise while braking soft pressure to the brake pedal. Heres what ive done so far...
1) Replaced hardware kit on the pads
2) Brand new rotors
3) new rim studs (2 had lost thread)
4) new bearings
Problem still exists....apply soft pressure to the brake pedal and you ll hear this loud ticking.....cant figure out what that noise is...and neither can 4 garage's in my neighborhood....please help.
May 11, 2009 at 3:32 PM
KHLOW2008
  • 41,812 POSTS
Hi bornflirt,
Thank you for the donation.
Since so many shops are not able to resolve the problem, it is not going to be easy and might require some diagnostics.
First I would like to know the following:
1. Are you able to identify which wheel or location of the source? Nearest location of source of noise helps.
2. Did the noise goes away after replacement of the items listed and comes back only after some driving? Was it exactly the same or were there any difference to the noise?
3. Did you check the CV joints?
4. Are the wheel rims standard? Did you check if there are any abrasions on the inner parts of the rims?
5. Do you feel anything from the brake pedal?
6. Any feelings felt at the steering wheel?
May 12, 2009 at 2:18 AM
BORNFLIRT
Here are replies to your answer gents:
- front drivers side wheel
- right after we tightened the caliper, the noise went away for a bit...but came back after some driving. Even from a cold start...noise only returns after a few mins of driving...
- had someone at pep boys look at the cv joint, they said it looked fine to them and they didnt see any problem with it.
- The rims are the stock ones. No damage was observed when i last removed it.
- brake pedal feels normal...no funny feeling though the pedal.
- same here...feels perfectly normal.
Also should have mentioned, we put 2 new studs on the wheel as the 2 previous studs lost their threading....
Please help cos its really starting to bug me that I cant find whats wrong with this car.
Thanks you.
Regards,
Zain Master
May 12, 2009 at 2:32 AM
