Engine Mechanical problem
1998 Acura Integra Two Wheel Drive Manual 150000 miles
I clean the iac valve today and adjust the valve lash...engine warm up look like better .I go take a ride with the car , all good.... I am happy for 15 second....
RPMS dropping when I put the gear in neutral . If I do not press on the gaz pedal when I drive the rpm dropping to 500rpm - 0rpm . Engine dont stall but is tight ...If the car are not moving RPM are good.
Oct 13, 2009 at 10:18 PM
