1998 Acura Integra rpm drop mystery
1998 ACURA INTEGRA
BUSSIE
  • 42 POSTS
Engine Performance problem
1998 Acura Integra 4 cyl Front Wheel Drive Manual
I start the engine... The rpm go to 1500rmp for 3 second after is go down to 1200rmp for 1 second and the car shake a lot when the rpm get down .
the only problem I have when the car is hot (750rpm) is when keep rolling with the car and I put the gear on neutral the rpm stop at 1000rpm . when the car was stop completely after 3 second, rpm go down and stay to 750rpm .
Sep 29, 2009 at 5:06 PM
F4I_GUY
  • 3,302 POSTS
Sounds like you have a faulty idle air control valve.
Oct 1, 2009 at 2:17 PM
BUSSIE
  • 42 POSTS
I have some error code oxygen sensor and misfire is what it can be the cause of my drop idle?
Oct 7, 2009 at 3:47 PM
