1998 Acura Integra new master cylinder
115,000 MILES • 4 CYL • FWD • AUTOMATIC
NASMAR
I bled my brakes and refilled the reservoir and did it all by the book. After that my brakes didn't work well at all. My pedal would go all the way to the ground, so I replaced the brake master cylinder with a brand new one and now I have no brakes whatsoever. Do I have to bleed the brakes all over again before I fill the sysem backup? I am totally stumped!
Jan 27, 2009 at 10:41 AM
ZACKMAN
  • 4,202 POSTS
Every time brake system is interrupted (in your case, master cylinder replacement), you need to bleed the brake system. Even though you have bled, the system, that was before the replacement of M/C. Bleed the system again.
Jan 27, 2009 at 2:36 PM
