1998 Acura Integra burning oil
1998 ACURA INTEGRA
15,100 MILES • 4 CYL • FWD • MANUAL
1STIMPORT
i've got an 98 integra gsr it has 151,000 n it's started to burn oil it goes trough a quart in 2 weeks.. one of the good things is that i got the car for free too. i would like to get some help in figuering out what could be the problem..
Jun 10, 2009 at 1:21 PM
  • 31,937 POSTS
Hi there,
A wet and dry compression test will give you a fair indication as to ring condition, do the dry test first and note the readings, then add a small amount of oil to the cylinders do this one at a time checking compressions as you go, the oil will temp seal up faulty rings and the comp will increase, if the comp is still low, it will be a valve problem, start here.
mark (mhpautos)
Jun 10, 2009 at 5:48 PM
