1997 Acura Integra Stereo
DAISYDUKEOFCARROLL
Electrical problem
1997 Acura Integra 4 cyl Wheel Drive Type unknown Automatic 153000 miles
I have the factory stereo still installed and Iam getting a weird message across the front of it when I insert any kind of cd! and if the cd works in the unit after installing it 6 times every bump I go over or anything of that sort It ruins my cd. I curretly needed new motor mounts because my motor is shifting would that have anything to do with my stereo issue? Should I purchase an aftermarket stereo to install to see if I have the same issue with it?
Jan 2, 2008 at 1:13 AM
JEREMIAH
  • 217 POSTS
what kind of message? DISC means that there is a problem with the disc you are inserting. ERR-E1 thru E7 means that there is an internal problem with the factory audio unit,ranging from the rollers to the laser itself.either way,i doubt you can repair an audio unit.
it happens more because of age than anything else.
the aftermarket unit is a personal preference,so you will have to decide for yourself.i suggest you check prices first,though.
Jan 12, 2008 at 5:20 PM
