1997 Acura Integra low MGP
1997 ACURA INTEGRA
149,000 MILES • 4 CYL • 2WD • MANUAL
SERGIO06
I have a problem and really need help I have a honda civic 1993 with a b18b1 from an acura integra 1997 ok I just got the pistons fixed because it was throwing a lot of smoke from the exhuast and I just started driving it I filled up the gas tank and it wasted gas like if it was a v6 or v8 I got the car because I wanted a gas saver I did the thing where I read the check engine light codes and my map and tp sensor came up I want to kno if that is causing it to waste gas or any other idea that would make my car waste gas thanks
Jun 13, 2009 at 11:20 AM
F4I_GUY
  • 3,302 POSTS
Check to see that the MAP sensor and TPS sensor clips are plugged into the PROPER locations! You can very easily mix up these two harness plugs. However, the car would be running very rough.
If that's not the case, you may have to replace both sensors.
Jun 13, 2009 at 11:25 AM
