1997 Acura Integra Leaking coolant
1997 ACURA INTEGRA
100,000 MILES • 4 CYL • 2WD • MANUAL
MARTIN91088
I have a 97 honda civic hatchback, with a 97 integra motor LS in it. Ive had the car now for about 2 years. Latley when I been driving it has been over heating on me. I put coolant in the radiator and I don't see any leaks from the radiator. But I did notice that the coolant was leaking from where the head and block connect? Is this going to cost alot of money? I really appreciate the help thanks.
Oct 9, 2010 at 9:18 AM
KHLOW2008
  • 41,814 POSTS
Hi Martin91088,
When there is insufficient coolant in system, it would overheat. Hopefully you have not damaged the engine.
This engine has a very slim chance of leaking between the head and block. Recheck the leak, it could be from a joint/hose somewhere above or nearby splashing the coolant onto the area you mentioned.
Is the leak from fron or rear of engine?
Where is the exact location?
Oct 9, 2010 at 9:27 AM
MARTIN91088
The leak is from the front and the left side Kinda by where the headers bolt up ?
Oct 9, 2010 at 11:11 AM
KHLOW2008
  • 41,814 POSTS
That could possibly be from the outlet hose ( upper radiator hose ) if the joint or hose is bad, coolant would leak and seep onto the head and would seem like the head gasket is leaking.
Coolant leakages would leave signs of oxidation.
Oct 9, 2010 at 2:26 PM
MARTIN91088
Okay Thank you I'll keep you updated too see what happens I hope it's just a head gasket I would need to replace....
Oct 9, 2010 at 4:22 PM
KHLOW2008
  • 41,814 POSTS
Head gasket job is not going to be cheap. A hose or joint would be much cheaper and easier to resolve.
Oct 9, 2010 at 5:26 PM
MARTIN91088
Thank you for everything! it was a bad hose
It took me 5 Min. to put it on. Thanks much
Oct 12, 2010 at 5:09 PM
KHLOW2008
  • 41,814 POSTS
You're welcome and glad to know you have fixed the problem.
Have a nice day.
Oct 13, 2010 at 2:25 AM
