1997 Acura Integra Clutch Issue
1997 ACURA INTEGRA
165,000 MILES • 4 CYL • FWD • MANUAL
KRISH727
Hi - I have been having problem shifting gears on this car for the past 2 months. It shift easily sometimes and other times it is very hard to shift gear. I dont seem to have any other problem as when ia m not changing the gears the car is driving without any issues. Over last month it had gotten had and it is making lots of noises from the engines for the past one week. I am being told that the clutch needs replacement.
Dec 1, 2009 at 10:41 AM
KHLOW2008
  • CAR REPAIR CONTRIBUTOR
  • 41,814 POSTS
Hi krish727,
Symptoms does indicate a fault with the clutch.
Check if the clutch hydraulic is working correctly with sufficient fluid in master cylinder reservoir.
It coud be the hyrdraulic system that is faulty.
Dec 1, 2009 at 3:08 PM
