1997 Acura Integra 15amp (ac) Ignition fuse
1997 ACURA INTEGRA
65,000 MILES • 4 CYL • FWD • MANUAL
INTEGRAFAN_08
Hello i have a 1997 integra LS with a 1.8 vtech motor in it wich only has 65k miles on it i have recently had the problem of my 15 amp (ac) ignition fuse blowing when i drive a few blocks down the road i was wondering what could be causing the problem if it was a short somewhere or my distributor or ignition relay could be going bad ? could you help me ?
Sep 22, 2008 at 5:40 PM
KHLOW2008
  • 41,814 POSTS
Hi Integrafan_08,
You mean fuse #24 (15 A)?
ACG fuse. Components that uses this fuse are
1. SRS
2. PGM-F1 relay.
3. TCM
4. VSS.
5 Cruise control
6. ELD.
Shorint of any of the above components or their wiring can cause the blown fuse.
Sep 23, 2008 at 4:02 AM
INTEGRAFAN_08
i dont think so.. it has something to do with the distributor im not a mechaninc so i wouldnt no exactly i know when this fuse pops i loose all spark to my plugs and have no fire
Sep 24, 2008 at 3:43 AM
KHLOW2008
  • 41,814 POSTS
When this fuse blows, power is not being supplied to the distributor so it definitely would not be providing any sparks.
You need to isolate the cause from the list I posted earlier. It could be the distributor but I think an exposed wire is more likely.
Sep 24, 2008 at 4:40 AM
