1996 Acura Integra wont turn on
ELTURBITO2
Electrical problem
1996 Acura Integra 4 cyl Front Wheel Drive Automatic
the car was turnin on and running perfect but some people put some sugar in the gas tank and now that fix everything the car doesnt want to turn on and the check engine to turn on the fuel pump and others wont turn on and i checked all the fuses and main relay and nothing
Apr 3, 2010 at 8:58 AM
KHLOW2008
  • 41,812 POSTS
Hi elturbito2,
When the dash indicator lights do not cvome on, check ths ignition switch. It could be faulty.
With sugar in the tank, get the fuel tank flushed.
Apr 4, 2010 at 1:24 AM
ELTURBITO2
yea i did flush the tank and cleaned out the lines and injectors and fuel filter and fuel regulater its just that the you u kno wen when u put the key into ign its suppose to turn on the check engine so it could turn on the fuel pump and others and i changed fuel pump relay and it still does the same problem doesnt want to turn on the check engine
Apr 4, 2010 at 2:32 AM
KHLOW2008
  • 41,812 POSTS
Is it only the CEL that is not showing or are all the indicators not showing?
If only the CEL, then it could be a fault with the ECM or its wiring circuit.
If other indicators lights are not showing as well, then it could be a fault with the ignition switch.
Apr 4, 2010 at 2:51 AM
