1996 Acura Integra speedometer wont move at all.
1996 ACURA INTEGRA
HONDASHOCKER34
Electrical problem
1996 Acura Integra 4 cyl Front Wheel Drive Manual
i own a 1996 integera ls non-vtech, i motor swapped it to a jdm gsr vtech. and i bought a jdm ecu go with it. i'm using the stock ls harness. the speedometer worked fine for about 3 months, but then i hooked up a v-tech sub harness to make v-tech work, and when doing so one of my friends hooked up the iab sensor power wire to the vss wire (orange) i didnt know he did. vtech didnt work so looked over it and switched it and when i hooked the iab sensor right the speedometer quit working.? we replaced the speed sensor check all the wires the sensors getting and sending power. what could it be?
Sep 11, 2008 at 1:45 PM
