All but the driver power windows(4 door) have stopped working. They started to fail one a time. At first only the rear passenger side failed. I changed the switch with the other rear window switch and I could get it to run back up. After turning the car off it wouldn't go down. Then all the windows except the driver window failed. I installed a new window switch on the driver rear window and all the windows started to work. When I tried several hours later all but the driver window stopped working again. In addition the passenger lock will not lock the car doors. The key on the passenger side will lock all doors. This started at the same time as the window problem. All the fuses are OK.
Apr 15, 2010 at 1:49 PM
