1996 Acura Integra Interference or non-interference
122,000 MILES • 4 CYL • FWD • MANUAL
IGGI
The timing belt on my 96 integra snapped at about 65mph on the freeway it has a B18B1 engine . I am not sure if it is an interference engine and could have damaged some of the pistons and valves. I was going to start pulling the head but I figured asking first will save me some time
Mar 30, 2008 at 8:23 AM
BMRFIXIT
  • 19,053 POSTS
80 to 90 % you have a valve damage
Mar 30, 2008 at 9:19 AM
IGGI
When I go to remove the head can I take the head off with the rocker arm assembly and cams still intact to take it to a machine shop?
Thanks
Mar 30, 2008 at 12:25 PM
BMRFIXIT
  • 19,053 POSTS
do it right take all off
Mar 30, 2008 at 12:48 PM
IGGI
Can I find top dead center on cylinder one after repairing any damage and when replacing the head or do I run a chance of f-en it up again? I ask because the mechanic I took it to (before I decided to do it myself) already removed the timing cover, belts and distributer. I appreciate all your help.
Thanks,
iggi
Mar 31, 2008 at 10:10 AM
BMRFIXIT
  • 19,053 POSTS
HERE IS THE TIMING MARKS after installing all turn engine by hand few turn making sure you have the timing on correct may I suggest a manual too it will guide you through the process best of luck jack.
https://images.2carpros.com/forum/automotive_pictures/99387_acurat_1.jpg
https://images.2carpros.com/forum/automotive_pictures/99387_acurat1_1.jpg
Mar 31, 2008 at 10:31 AM
