1996 Acura Integra Integra Hesitating/Bogging Down
187,000 MILES • 4 CYL • FWD • MANUAL
MIKE66025
My Integra has been hesitating or bogging down as I drive it. It is most noticeable under acceleration. I do feel it some times at steady speeds. When the accelerator is to the floor I do not notice it. Engine idles great. This is an intermittent problem that happens when car is at operating temp; but not every time it is at operating temp. I did some research online and found that it could be EGR system or distributor. No EGR valve on this make/model. Bought new dizzy (and cap and rotor) and no bogging down for 20-25 miles. Then it started again. The car does puff out bluish smoke every morning when I first start her up, and when I take off from sitting at a stop light or at a drive thru windows for a couple of minutes. I assumed it was oil because I have to add 2 qts between each oil change; but I guess it also could be running extra rich. I did buy new spark plug wires; no fix. I also bought a new fuel filter when problem first occurred, no fix. I tightened down valve cover; thinking that oil was seeping to the spark plugs, no fix. The CEL is not on. It does come on for 2 seconds when starting the car up, then it turns off. There is pressure in gas tank after driving (I was hoping that a new gas cap would fix it!!).
Oct 22, 2009 at 9:56 AM
  • 75,988 POSTS
My Integra has been hesitating or bogging down-probable causes below
Oxygen sensor
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Oct 22, 2009 at 10:00 AM
