1996 Acura Integra fuel pump or injectors
1996 ACURA INTEGRA
26,500 MILES • 4 CYL • FWD • AUTOMATIC
SAMEVE1
my car just all of a sudden won't start. no previous issue. the motor turns but wont crank. not starter or battery. it is as if its not getting fuel. how can i test to see if fuel pump is working.
Nov 19, 2009 at 12:54 AM
KHLOW2008
  • 41,814 POSTS
Hi sameve1,
Open the gas cap and get some one to turn the ignition on while you listen at the fuel inlet hose. If the pump is working, there should be a whirring noise for about 2 seconds when the fuel pump primes the circuit.
Did you check if you are getting sparks?
Nov 19, 2009 at 4:09 AM
