OBD2 code says Automatic Transaxle P0700 and Acura code P1791 Transmission control system malfunction. Am I looking at an expensive repair?
Jul 6, 2008 at 12:01 AM
BMRFIXIT
✓Experienced Mechanic
Nothing is cheep today !!!!
any how that is a generic code and indicate that you have a trouble in the tranny and in its controls
you need to have the tranny control module scan for codes
doing so will give you a clear picture on what is going on
as for p1791 I have nothing on that recheck the code
always check fuses as a 1st step
good luck
Jul 6, 2008 at 12:42 AM
KHLOW2008
Hi jackc,
OBD I and II are not accurate when reading transaxle codes for non electronicaly controlled trans.
