1996 Acura Integra engine stalling
220,000 MILES • 4 CYL • 2WD • AUTOMATIC
MWAYNEP
When I press the gas pedal down normally such as staring of at a light or coming out of a parking lot the car wil stall. I have to barley pres on gas pedal till i build up speed then I still can't pres it down in order to pass. Also when I shut the car off it takes several times turning it over to start it. This all just happened. I've had no problem in past?
Oct 7, 2009 at 5:21 PM
KHLOW2008
  • 41,812 POSTS
Hi mwaynep,
Is the Check Engine Light showing while engine is running?
What is the idling speed?
Do you have any other performance issues while driving?
Oct 8, 2009 at 3:18 AM
