1996 Acura Integra Cylinder 1 Misfire Detected
152,000 MILES • 4 CYL • FWD • MANUAL
TOTTI10
I went to Auto Zone and borrowed the code scanner. The following codes came up. P0301, P0302, P0304 and P1300. what do they mean and what can i do to fix it.
thank you.
Jan 15, 2008 at 8:19 AM
BLACKOP555
  • 10,386 POSTS
P0301 is cylinder misfire on cylinder 1
P0302 is cylinder missfire on cylinder 2
po304 is cylinder missfire on cylinder 4
P1300 is random missfire,
you should check your coil/coil packs first.
Jan 15, 2008 at 11:51 AM
