1996 Acura Integra CV Joint Boots Replacement
122,000 MILES • 4 CYL • 4WD • AUTOMATIC
BUBBALOVESYOU2MUCH
I have a 1996 Acura Integra and took my car in for a timing belt replacement. After he was done, he also informed me that the CV joint boots in my car are almost cracked and needs to be replaced for $294.00. I haven't noticed any problems with my car, so my question is, when should the CV joint boots be replaced? My car has a mileage of 122,000. I just don't want to be taken in for unneccessary work, if it is the case. Thanks
Sep 23, 2008 at 8:03 AM
BLACKOP555
  • 10,386 POSTS
how can he see if their almost cracked? either they are cracked or their not.
and when its time to have them replaced replace the whole shaft its alot cheaper then having it torn apart and new boots put on, this one cuts the time in half.
Sep 23, 2008 at 12:41 PM
