1996 Acura Integra alarm system problems
1996 ACURA INTEGRA
DJCAPONE
Electrical problem
1996 Acura Integra 6 cyl Front Wheel Drive Manual
i have this car that use to run good and every thing was working fine then a friend messed with the alarm system and now the car wont start what would cause this to happen and how do you fix it??
Apr 25, 2009 at 2:35 PM
TED-E-DEE
  • 109 POSTS
Would it be possible to get more info. on what yor friend was trying to do, or what was he working on w/the alarm system ? What area of the vehicle was he doing repair on ? Was he trying to repair your alarm system ? Please send more info. . One thing I could have you try would be to turn on & off every electrical device on the car, see if there is anything else that is not working. If you find something else not working, ck. the fuse{s} to that component. Then,{one @ a time, pull & ck. all of the fuses in all of your fuse boxes. There is usually one inside the car & one or two under the hood. It would not hurt to ck. for continuity on both sides of the fuses, sometimes you can't see where they are split. If you don't have any luck w/that, please send more info if you can.
Apr 26, 2009 at 12:01 AM
