1996 Acura Integra 96IntegraLs
1996 ACURA INTEGRA
96INTEG
1996 Acura Integra 4 cyl Front Wheel Drive Automatic
My crank pulley came off while driving on the interstate(the bolt backed out?). I got a new bolt and replaced the pulley and the belts ,now it wont start.any suggestions?????
May 15, 2010 at 12:07 PM
KHLOW2008
  • 41,814 POSTS
Hi 96integ,
If the crank sprocket for the timing belt was damaged or dislodged, the timing belt would be out of time.
Check the timing belt symchronisation.
May 15, 2010 at 7:09 PM
96INTEG
there didn't appear to be any damage to anything the new key and bolt went right back in with out any problems.
May 16, 2010 at 2:51 AM
KHLOW2008
  • 41,814 POSTS
Once the key is dislodged due to the crank pulley coming off, the valves can be damaged. Get a compression test done.
As I mentioned earlier, check the timing belt synchronisation.
May 16, 2010 at 3:10 AM
