1996 Acura Integra
ILUVHUMMINGBIRDS
  • 1996 ACURA INTEGRA
1996 Acura Integra Two Wheel Drive Manual 140, 00 miles
I have electronic doors. A few months ago I had trouble with my alarm system to where I couldnt turn it off and took to alarm co, they disconnected it. Recently I cant unlock my drivers door with the key nor will it unlock from the inside. Also the passenger door u can unlock with the key but it will re lock on its own. Can u help me
Saturday, September 18th, 2010 AT 5:48 PM
KHLOW2008
  • 41,814 POSTS
Hi Iluvhummingbirds,
Problem should be the driver door lock actuator. It is stuck in the closed position resulting in you not being able to unlock it.
When the passenger door is unlocked, the driver door lock signal would signal to the control unit that the door should be loced thus it locks itself again.
You need to open up the driver door panel to get to the door lock actuator and replace it, not easy if the door cannot be opened.
This could also be the problem why the alarm system malfunctioned.
Saturday, September 18th, 2010 AT 10:38 PM
