1995 Acura Integra whistleing noise
1995 ACURA INTEGRA
195,599 MILES • 4 CYL • FWD • MANUAL
GRACIA_THANKSU
When I am driveing and let off the gas i can hear a whistleing noise coming from under the hood. When i poped the hood and revved the egine it sounded like it was coming from the intake, but i can tell
Jun 2, 2010 at 2:12 AM
2CARPRO JACK
  • 11,533 POSTS
Try carefully spraying carb cleaner around the intake area while it is idling.If the idle changes, you have sprayed a leak.Might be the PCV valve or the line to it, possibly even an intake gasket, does it run smooth even though it whistles?
Jun 2, 2010 at 7:20 AM
