1995 Acura Integra tire leans out
189,000 MILES • 4 CYL • 2WD • AUTOMATIC
DRAGN1274
i just bought an acura integra knowing it needed a wheel bearing while looking at it i noticed the passenger side front sat higher the the other the top of the tire on that side leans out wht caauses this how do i correct it
Sep 5, 2010 at 6:22 AM
MADMIKE1735
  • 951 POSTS
if you want to fix this, it will cost a few bucks... one side sits higher dew to the front struts.... replace both!!! this will insure the car sits level.... afterwards, have an alignment done, that will insure your camber is corrected after replacing the struts....
Sep 7, 2010 at 2:36 PM
