My daughter's car (recently purchased) had the belt changed at 65,000, but does not know if it has been changed since. Since there does not seem to be any symptons of this belt's problems other than the engine shutting down, how can one check to see it the belt needs hanging other than opening the engine (expensive) to see if the prior owners may have had the belt changed since the last one at 65,000, or if it even needs one?
Can you trust the CARFAX system to correctly show all work that has been done to the vehicle?
The local Honda dealer has a deal for $600 this month for the timing belt and water pump replacement . Should we just go ahead and get it done to not have to worry about it in the future?
Thank you,
Jake
Thank you,
Jake
Mar 15, 2008 at 2:29 PM
