1995 Acura Integra Ecu makes a buzzing noise and gauges dan
1995 ACURA INTEGRA
JTWACHTENDORF
Electrical problem
1995 Acura Integra 4 cyl Front Wheel Drive Manual
Ok I have a motor swap in a civic with a 95 integra motor and what is happening is I had the car apart and finally put it back together after several months and I went to prime the oil pressure and the motor turned over twice and stopped. Now all the car does when I put the key in the ignition is the gauges dance around and the ecu ( computer) makes and buzzing noise.
Mar 16, 2010 at 8:20 AM
KHLOW2008
  • 41,814 POSTS
Hi Jtwachtendorf,
Thank you for the donation.
Seems you have a ground circut problem.
Recheck the ground cable at transmission end and the ground connection at the thermostat housing for looseness, broken wire or contaminations.
Mar 17, 2010 at 12:42 AM
