1995 Acura Integra Timing belt and idling issue
1995 ACURA INTEGRA
65,000 MILES • 4 CYL • FWD • AUTOMATIC
SUMAC0401
  • 13 POSTS
I recently changed my timing belt a few weeks back. Everything seems okay, the car drives without hesitation or anything like that (its a 1995 Integra LS 3 door automatic transmission). I've driven it over 1,000 miles since the belt change without any issues.
However, I notice that when I open the hood and "by hand" rev the throttle and then let go of it, when it stops revving and idles, the engine moves/hesitate/shakes a little bit...not much but you can tell. When the car is idling, its pretty smooth but once every few seconds, it hits a tiny-tiny rough spot. Not sure...but am I a teeth off the Top Dead Center mark on the crank, intake and exhaust? I know I lined everything up before I put back everything.
Maybe the car idles that way since it is13 years old....
Additionally, when I changed the belt, I also flush the power steering belt at the same time. After putting everything back together and starting the car, the idle drop and car almost feel like it was about to die when I turn all the way to the left or right, but I adjusted the idle adjustment screw and now the idle is normal (750 RPM) as per the oem Acura Integra repair manual. Not sure if this is related to the tiny rough idle issue I'm concern with.
Please provide any expert advice. Thank you and much appreciated.
Sep 10, 2008 at 7:48 AM
Check the engine compression if its up to specifications and also check ignition timing -Do a major tune-up.
Sep 10, 2008 at 8:21 AM
SUMAC0401
  • 13 POSTS
A tune up was already done at 55K mile mark (i.e. spark plug, air filter). I'm pretty sure the compression should be okay since the previous owner (whom I'm related to) took the car to Acura dealership with all the maintenance stuff based on the owner's manual schedule.
I have not try the ignition timing check yet.
Again, could I be a teeth off on the Top Dead Center (TDC) point? Thanks.
Sep 10, 2008 at 8:30 AM
The only way out on this is to open it back up and verify it-could also be a problem with the sensors in the distributor/TDC/CPS
Sep 10, 2008 at 8:43 AM
SUMAC0401
  • 13 POSTS
I'll try the ignition timing later on.
BTW, I was reading how to do that. The repair manual show that I need to remove the bolt holding the distributor and turn counter clockwise to "advance" the timing or clockwise to "retard" the timing. Which should I do with my minor symptom? Is there anything else I need to do for a ignition timing test? Thanks.
Sep 10, 2008 at 8:52 AM
